Home Motherboards
Maximized Mainstream Value
14. winRAR & x264 HD
  • 4. Closer Look (Aesthetics)
  • 6. Closer Look (Lower Half)
  • 9. Adobe Performance
  • 11. DaVinci & Handbrake
  • 12. POV-Ray & OpenSCAD
  • 13. SolidWorks & TrueCrypt
  • 14. winRAR & x264 HD
  • 15. AC:V & Borderlands 3
  • 16. CS: GO & Metro Exodus
  • 17. RDR2 & Tomb Raider
  • 19. Scorecard & Summary
  • 20. Closing Thoughts
winRAR Benchmark
MSI MPG Z790 EDGE Ti Max WiFi Review 91
x264 HD Benchmark
MSI MPG Z790 EDGE Ti Max WiFi Review 85
Page 14 of 20
Crucial P5 Plus 2TB Review
September 23, 2021
