Liquid Suprim'acy
in GPU, Reviews
18. Temperature, Noise, and Power Analysis
  • 6. Closer Look p.4
  • 8. AC: Mirage, Cyberpunk 2077
  • 9. Battlefield 5, CoD: MWII
  • 10. Crysis 3, Far Cry 6
  • 11. GTA V, Hitman 3
  • 12. Metro Exodus, S.T.R.
  • 14. Ray Tracing Performance
  • 15. Adobe PP & Blender
  • 16. DaVinci, Handbrake, Topaz AI
  • 17. Overclocking
  • 19. Closing Thoughts
MSI RTX 5090 Suprim Liquid SOC Review 97
Sound Level Test Results
While everyone “hears” noise differently there is one easy way to remove all subjectiveness and easily compare different fans: use a sound level meter. This way you can easily compare the various fan’s noise envelopes without us coloring the results and see what fans fit within your comfort level. Of course, we will endeavor to try and explain the various results – which are taken at a 15-inch distance from the GPU’s fan(s) – to help you gain an even better understanding of how loud a cooler’s stock fan is, but even if you discount our personal opinions, the fact remains numbers don’t lie.
MSI RTX 5090 Suprim Liquid SOC Review 98
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potential crop up because of brownouts and power spikes.
MSI RTX 5090 Suprim Liquid SOC Review 99
  • 17. Overclocking
Page 18 of 19
Tags: 360mm AIOAI ProcessingCUDA CoresEnthusiast PCgaming PCGDDR7GPUGraphics CardHardware ReviewHigh-End GPULiquid CoolingMSINvidiaOverclockingPC buildPC Hardwareperformancepower efficiencyProfessional GPUQuiet GPURTX 5090Suprim Liquid OCtech innovationWorkstation
MSI Prestige 16 AI Evo 2025 Video Review
May 22, 2025
