in Storage, Reviews
13. Boot time and Data Transfer
  • 4. Closer Look p.1
  • 5. Closer Look p.2
  • 6. Closer Look p.3
  • 7. Closer Look p.4
  • 8. Testing Methodology
  • 9. Sequential Performance
  • 10. ATTO Disk Benchmark
  • 12. IOMeter
  • 14. Adobe & VMWare
  • 15. Game Load Time
  • 18. Score Card and Summary
  • 19. Closing Statement
System Boot Time
Crucial Pro T700 2TB PCIe 5 NVMe Review 43
Real World Data Transfers
Crucial Pro T700 2TB PCIe 5 NVMe Review 44
Crucial Pro T700 2TB PCIe 5 NVMe Review 45
  • 12. IOMeter
Page 13 of 19
