MSI MPG CoreLiquid P22 360 Review
Across the Board Improvement
6. Testing Methodology
  • 5. Installation & Quirks
  • 7. Performance Results
  • 9. Score Card and Summary
  • 10. Closing Statement
This different approach starts with testing on two testbeds and not just one. The first is an Intel 13th generation Core i9-13900K CPU. This CPU’s thermal characteristics make it a good representation of for what most upper-mainstream users will experience. For AMD fans, we have an new Ryzen 9 9950X3D processor. A processor that just does not like to run cool.
Further helping to give as clear a picture of a given cooler’s real-world performance, we also will be testing a test sample with stock number of fans (i.e. whatever number is included in the box), and (when possible) the maximum number of fans. For most air-based coolers this means one fan for stock, and two to three for maximum results; whereas with water-based stock could be one to three, and three to six for maximum.
Since not all fans are made the same, we will also be testing the review sample at various fans speeds. While many can go below 800rpms few will not spin at below this level and fewer still do so while keeping temperatures in check. This is why we have chosen 800RPM as the minimum fan speed cut-off, and from then on we increase the rotational speed in 200 to 250 RPM increments until the fan is running at ‘full speed’. This can vary from 1200 to over 3000… and will help highlight how much – or little – extra performance the increase in rotational speed brings to the table. Our personal cut off for CPU temperature is 90 degrees, but to give as full a picture as possible we have opted (when possible) for 95 C as the cutoff and as such once 95-degree temperature results are reached no further results below that fan speed will be included.
Intel Testbed:
Memory: Crucial Pro DDR5-5600
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 11 Professional
AMD Testbed:
Processor: AMD Ryzen 9 9950X3D
Motherboard: MSI MPG X870E Carbon MAX WiFi
Cooling: Various
Page 6 of 10
Previous 12345678910 Next
Tags: 360mm AIOAIO cooleramd ryzen 9000best aio cooler 2026budget friendly pc componentsCPU Cooler Reviewcpu coolinglcd screen aioLiquid CoolingMSImsi mpg coreliquid p13msi mpg coreliquid p22msi p22 vs p13PC BuildingPC hardware review
Crucial P5 Plus 2TB Review
September 23, 2021
