in Storage, Reviews
  • 4. Closer Look p.1
  • 5. Closer Look p.2
  • 6. Closer Look p.3
  • 7. Closer Look p.4
  • 8. Testing Methodology
  • 9. Sequential Performance
  • 10. ATTO Disk Benchmark
  • 12. IOMeter
  • 14. Adobe & VMWare
  • 15. Game Load Time
  • 18. Score Card and Summary
  • 19. Closing Statement
Crucial Pro T700 2TB PCIe 5 NVMe Review 7
For those that are new(er) to SSD technology and want to know exactly what ‘Replacement Gate Technology’ is… a bit more theory and information is needed. The foundation of all Not-AND (aka ‘NAND’) Solid State storage is a tiny little electrical gate, and a tiny little electrical ‘battery’ cell called a transistor. To change the stored data bit from a 0 to 1, or vice versa, the controller tells the gate to either let the charge ‘out’ (aka ‘discharge the cell’) or store some in the cell. This is called a program operation as it is literally setting the charge state of cell or ‘programming’ it
Crucial Pro T700 2TB PCIe 5 NVMe Review 8
Crucial Pro T700 2TB PCIe 5 NVMe Review 9
Crucial Pro T700 2TB PCIe 5 NVMe Review 10
Crucial Pro T700 2TB PCIe 5 NVMe Review 11
Crucial Pro T700 2TB PCIe 5 NVMe Review 12
Crucial Pro T700 2TB PCIe 5 NVMe Review 13
Crucial Pro T700 2TB PCIe 5 NVMe Review 14
Crucial Pro T700 2TB PCIe 5 NVMe Review 15
  • 12. IOMeter
Page 3 of 19
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
