Home Ram
Silicon Power XPower Turbine RGB DDR4-3200 Review
Putting the Budget back in RGB
in Ram, Recent, Reviews
Silicon Power DDR4 16GB (8GBx2) RGB RAM Turbine Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V...
Silicon Power DDR4 16GB (8GBx2) RGB RAM Turbine Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V UDIMM Desktop Memory Module - Low Voltage (SP016GXLZU320BDB)
Silicon Power DDR4 16GB (8GBx2) Zenith RGB RAM Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V UDIMM...
Silicon Power DDR4 16GB (8GBx2) Zenith RGB RAM Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V UDIMM Desktop Memory Module - Low Voltage SP016GXLZU320BDD
6. Adobe Performance
  • 5. Overclocking Results
  • 6. Adobe Performance
  • 8. AC, BF 4, Crysis
  • 9. GTA V, Metro: LL
  • 10. WinRAR, x264 HD
Adobe Photoshop CC
Adobe Photoshop is a raster graphics editor developed and published by Adobe Systems for macOS and Windows. To further make loading slower we have included a bunch of extra brushes that need to be loaded before the program is ready to use.
Silicon Power XPower Turbine RGB DDR4-3200 Review 22
Adobe Premiere Elements
Adobe Premiere Elements is a video editing software published by Adobe Systems. It is a scaled-down version of Adobe Premiere Pro and is tailored to novice editors and consumers. The entry screen offers clip organization, editing and auto-movie generation options. To stress the CPU we have disabled GPU rendering and instead Premier will use the CPU only.
Silicon Power XPower Turbine RGB DDR4-3200 Review 23
Page 6 of 12
Tags: BallistixBallistix MemoryDDR4memorypcmrRAMreviewSilicon PowerTurbine RGBXpower
