Home Ram
Silicon Power DDR4-2400 Review
Good choice for the adventurous buyer
in Ram, Recent, Reviews
Silicon Power DDR4 8GB 3200MHz (PC4-25600) CL22 SODIMM 260-Pin 1.2V Gaming Laptop RAM Notebook...
Silicon Power DDR4 8GB 3200MHz (PC4-25600) CL22 SODIMM 260-Pin 1.2V Gaming Laptop RAM Notebook Computer Memory
10. WinRAR, x264 HD
  • 5. Overclocking
  • 6. Adobe Testing
  • 8. AC, BF 4, Crysis
  • 9. GTA V, Metro: LL
  • 10. WinRAR, x264 HD
winRAR Benchmark
Silicon Power DDR4-2400 Review 28
x264 HD Benchmark
Silicon Power DDR4-2400 Review 29
10. WinRAR, x264 HD
  • 5. Overclocking
  • 6. Adobe Testing
Page 10 of 12
Tags: DDR4DDR4 2400pcmrRAMRam ReviewSilicon Power
HyperX Pulsefire FPS Review
