Good things can come in small packages
in Storage, Recent, Reviews
Seagate Ultra Touch HDD 2TB External Hard Drive – Black USB-C USB 3.0, 1yr Mylio Create, 4 month...
Seagate Ultra Touch HDD 2TB External Hard Drive – Black USB-C USB 3.0, 1yr Mylio Create, 4 month Adobe Creative Cloud Photography plan and Rescue Services (STHH2000400)
Seagate Backup Plus Ultra Touch HDD 1TB External Hard Drive – White USB-C USB 3.0, (STHH1000402
Seagate Backup Plus Ultra Touch STHH1000400 1 TB Portable Hard Drive - External - Black
5. Synthetic Performance
  • 7. Score Card & Summary
ATTO Disk Benchmark
Seagate Backup Plus Ultra Touch 1TB Review 20
Seagate Backup Plus Ultra Touch 1TB Review 21
AS-SSD
Seagate Backup Plus Ultra Touch 1TB Review 22
Seagate Backup Plus Ultra Touch 1TB Review 23
Crystal DiskMark
Seagate Backup Plus Ultra Touch 1TB Review 24
Seagate Backup Plus Ultra Touch 1TB Review 25
Page 5 of 8
Tags: BX300BX500CrucialCrucial MX500Crucial SSDExternal StorageHard DriveHDDLaCiem2memoryMX300MX500NVMEP1P34A80pcmrPortable StoragereviewSeagateSeagate backup plusSilicon PowerSolid State DriveSSDSSD ReviewstorageStorage Reviewsuper fast nvmeValue SSDValue SSD Review
XFX GTS Radeon RX 580 Black Review
