PNY XLR8 GTX 980 Pro
in GPU, Reviews
PNY XLR8 CS3040 2TB M.2 NVMe Gen4 x4 Internal Solid State Drive (SSD) - M280CS3040-2TB-RB
PNY XLR8 CS3140 1TB M.2 NVMe Gen4 x4 Internal Solid State Drive (SSD) - M280CS3140-1TB-RB​
PNY XLR8 CS3030 500GB M.2 PCIe NVMe Gen3 x4 Internal Solid State Drive (SSD), Read up to 3,500 -...
PNY XLR8 CS3030 500GB M.2 PCIe NVMe Gen3 x4 Internal Solid State Drive (SSD), Read up to 3,500 - M280CS3030-500-RB
14. PNY XLR8 GTX 980 Pro – Temperature, Noise, and Power Analysis
  • 1. PNY XLR8 GTX 980 Pro – Intro
  • 2. PNY XLR8 GTX 980 Pro – Specifications and Features
  • 3. PNY XLR8 GTX 980 Pro – A Closer Look
  • 4. PNY XLR8 GTX 980 Pro – Testing Methodology
  • 5. PNY XLR8 GTX 980 Pro – Sleeping Dogs(SGB)
  • 6. PNY XLR8 GTX 980 Pro – Metro: Last Light(SGB)
  • 7. PNY XLR8 GTX 980 Pro – BioShock Infinite(SGB)
  • 8. PNY XLR8 GTX 980 Pro – Tomb Raider(SGB)
  • 9. PNY XLR8 GTX 980 Pro – Batman Arkham Origins(SGB)
  • 10. PNY XLR8 GTX 980 Pro – Battlefield 4(RWGB)
  • 11. PNY XLR8 GTX 980 Pro – Assassins Creed: Black Flag(RWGB)
  • 12. PNY XLR8 GTX 980 Pro – Call of Duty: Ghosts(RWGB)
  • 13. PNY XLR8 GTX 980 Pro – Crysis 3(RWGB)
  • 14. PNY XLR8 GTX 980 Pro – Temperature, Noise, and Power Analysis
  • 15. PNY XLR8 GTX 980 Pro – Overclocking
  • 16. PNY XLR8 GTX 980 Pro – Performance Summary and TL;DR
  • 17. PNY XLR8 GTX 980 Pro – Closing Statement
PNY XLR8 GTX 980 Pro 41
When you take two large and efficient fans, pair it to a high performance custom heatsink and use it on a rather cool running core the end results are indeed impressive. Simply put, even though PNY provides their 980 Pro customers with a large factory overclock its Maxwell core is still happy and cool running. Color us impressed.
Sound Level Test Results
For Idle tests, we let the system idle at the Windows 7 desktop for 25 minutes and recorded the peak dB.
PNY XLR8 GTX 980 Pro 42
We expected great things from the 980 Pro and we were not disappointed. No matter how noise sensitive you will like the 980 Pro as this is one quiet card.
System Power Consumption
PNY XLR8 GTX 980 Pro 43
Even though this card is heavily overclocked it will only cost you an extra 19 watts of electricity compared to a reference GTX 980. This may be higher than the 15 watts the increased TDP would lead you to believe but 19 watts is nothing in the grand scheme of things – our front speakers use more than that.
Page 14 of 17
Tags: Gaming GPU. High end 980GTX 980GTX 980 ProNvidiaPNY XLR8 GTX 980 ProXRL8
Corsair Announces 128GB DDR4 Memory Kits
