MSI Radeon RX 6700 XT Gaming X Review
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 3.0 Fans FreeSync DirectX 12 VR...
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 3.0 Fans FreeSync DirectX 12 VR Ready Graphics Card (RX 6700 XT MECH 2X 12G)
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 3.0 Fans FreeSync DirectX 12 VR Ready OC Graphics Card (RX 6700 XT MECH 2X 12G OC) (Renewed)
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 4.0 Fans FreeSync DirectX 12 VR...
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 4.0 Fans FreeSync DirectX 12 VR Ready RGB Graphics Card (RX 6700 XT Gaming X 12G)
4. Closer Look p.2
  • 1. MSI Radeon RX 6700 XT Gaming X
  • 7. Overclocking Results
  • 8. AC: Odyssey, Battlefield 1
  • 9. Battlefield 5, CoD: BO5
  • 10. Crysis 3, Far Cry 5
  • 11. Far Cry New Dawn, GTA V
  • 12. Hitman 2, Metro Exodus
  • 13. RAGE 2, Shadow of Tomb Raider
  • 14. Strange Brigade, The Division 2
  • 17. Analysis and Comparison
  • 18. Closing Thoughts
MSI Radeon RX 6700 XT Gaming X Review 13
The last thing you will notice upon picking up the card for the first time is its weight. This is a hefty card… nearly 10.5 ounces heavier than an AMD reference Radeon RX 6700 XT. There Aint No Such Thing As A Free Lunch and this how MSI (and others) are able to not only offer better clock rates (especially during extended gaming sessions) but (relatively) compact form-factors compared to the various 3-fan equipped models.
MSI Radeon RX 6700 XT Gaming X Review 14
Unlike the plastic facia, this added weight has been put to very good use. Hidden underneath that plastic fascia and dual fan combination is five precision machined heatpipes in what MSI calls a ‘Core Pipe’ configuration. These heatpipes are in turn cooled via two rather large cooling arrays, which in turn is cooled by two “Torx Fan 4.0” 95mm fans. This combination is what MSI calls their TWIN FROZE 8 cooling system and it is impressive.
MSI Radeon RX 6700 XT Gaming X Review 15
Let’s start with the fans. These fans not only focus the airflow for more efficient cooling (i.e. higher static pressure at lower speeds and noise) they are also much more robust and durable than the typical ten blade design. Typically, ten blades mean each fan is thin and fragile… and eventually will catastrophically fail and smack you in the face if you are unlucky (yes this has happened with another manufacturer’s earlier generation card). While that is technically true for Torx Fan 4.0 fans, MSI has clustered them into five groups of two, with the end of each fan bladed connected to the end of the other blade in its cluster. This significantly reduces flex and overall stress on the fan’s plastic… and as an added bonus results in an actually quieter fan. In testing the fans will stop when the temperatures are low. Even during extended gaming sessions the default fan profile kept them in the 1250-1300 rpm range, at whisper quite noise levels… while also keeping temperatures well below 70degrees Celsius (typically in the mid 60s).
MSI Radeon RX 6700 XT Gaming X Review 16
Excellent fans however are only part of the equation… and if paired with a mediocre cooling solution they would not be able to do that voodoo that they do. This is where the added width and height come into play. To help keep ‘dead zones’ or air high pressure eddies / zones from forming from having multiple fans MSI has cut the cooling array into two zones with about a 1-inch gap between each cooling zone.
MSI Radeon RX 6700 XT Gaming X Review 17
Each array is about an inch tall.
MSI Radeon RX 6700 XT Gaming X Review 18
Each array is nearly 4.5inches wide.
MSI Radeon RX 6700 XT Gaming X Review 19
The back (nearest IO ports) array is about 4.2 inches long.
MSI Radeon RX 6700 XT Gaming X Review 20
The front (nearest the dual 8-pinc PCIE power ports) is about 4.1 inches long.
With these numbers it is pretty easy to calculate a rough surface area (and extremely rough cubic area). Doing the math, we get about 37 and half square inches of surface area for cooling. To put that in perspective that is only about 7(ish) square inches less than many decent 3-fan models. Needless to say, when you mix in the fact that the heatsinks actively cool not just the NAVI 22 XT core but also the Samsung GDDR6 memory and the 8+2 all digital VRM, this ‘small’ MSI Gaming X 6700XT has a veritable ton of cooling potential. On a 230 watt TDP card. Now that is pretty much the classic definition of ‘overkill’.
4. Closer Look p.2
Page 4 of 18
Tags: 60006700xtAMDGPUMSIMSI Radeon RX 6700 XT Gaming X ReviewradeonreviewRX 6700 XT
GIGABYTE AORUS 4K Gaming Monitors Are New-Gen
