MSI Radeon RX 6700 XT Gaming X Review
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 3.0 Fans FreeSync DirectX 12 VR...
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 3.0 Fans FreeSync DirectX 12 VR Ready Graphics Card (RX 6700 XT MECH 2X 12G)
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 3.0 Fans FreeSync DirectX 12 VR Ready OC Graphics Card (RX 6700 XT MECH 2X 12G OC) (Renewed)
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 4.0 Fans FreeSync DirectX 12 VR...
MSI Gaming Radeon RX 6700 XT 192-bit 12GB GDDR6 DP/HDMI Dual Torx 4.0 Fans FreeSync DirectX 12 VR Ready RGB Graphics Card (RX 6700 XT Gaming X 12G)
16. Temperature, Noise, and Power Analysis
  • 1. MSI Radeon RX 6700 XT Gaming X
  • 7. Overclocking Results
  • 8. AC: Odyssey, Battlefield 1
  • 9. Battlefield 5, CoD: BO5
  • 10. Crysis 3, Far Cry 5
  • 11. Far Cry New Dawn, GTA V
  • 12. Hitman 2, Metro Exodus
  • 13. RAGE 2, Shadow of Tomb Raider
  • 14. Strange Brigade, The Division 2
  • 17. Analysis and Comparison
  • 18. Closing Thoughts
MSI Radeon RX 6700 XT Gaming X Review 77
Sound Level Test Results
While everyone “hears” noise differently there is one easy way to remove all subjectiveness and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us coloring the results and see what fans fit within your personal comfort level. Of course, we will endeavor to try and explain the various results – which are taken at a 15 inch distance from the GPU’s fan(s) – to help you gain an even better understanding of how loud a cooler’s stock fan is, but even if you discount our personal opinions, the fact remains numbers don’t lie.
MSI Radeon RX 6700 XT Gaming X Review 78
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potential crop up because of brownouts and power spikes.
MSI Radeon RX 6700 XT Gaming X Review 79
Page 16 of 18
Tags: 60006700xtAMDGPUMSIMSI Radeon RX 6700 XT Gaming X ReviewradeonreviewRX 6700 XT
GIGABYTE AORUS 4K Gaming Monitors Are New-Gen
May 9, 2014
