6. Sequential Performance
  • 4. BiCS 3 primer
Read Bandwidth
Gigabyte Aorus RGB NVMe 256GB M.2 Review 23
Write Performance
Gigabyte Aorus RGB NVMe 256GB M.2 Review 24
  • 4. BiCS 3 primer
Page 6 of 16
