“Rightsizing” done right
Crucial X8 1TB Portable SSD – Up to 1050MB/s – USB 3.2 – External Solid State Drive, USB-C, USB-A...
Crucial X8 1TB Portable SSD – Up to 1050MB/s – USB 3.2 – External Solid State Drive, USB-C, USB-A – CT1000X8SSD9
Crucial X8 500GB Portable SSD – Up to 1050MB/s – USB 3.2 – External Solid State Drive, USB-C,...
Crucial X8 500GB Portable SSD – Up to 1050MB/s – USB 3.2 – External Solid State Drive, USB-C, USB-A – CT500X8SSD9
Aenllosi Hard Carrying Case Case Compatible with Crucial 1TB/500GB X8 Portable SSD (Carrying)
5. Synthetic Performance
  • 7. Score Card and Summary
ATTO Disk Benchmark
Crucial X8 Portable SSD 1TB Review 17
Crucial X8 Portable SSD 1TB Review 18
AS-SSD
Crucial X8 Portable SSD 1TB Review 19
Crucial X8 Portable SSD 1TB Review 20
Crystal DiskMark
Crucial X8 Portable SSD 1TB Review 21
Crucial X8 Portable SSD 1TB Review 22
Page 5 of 8
Tags: CrucialCrucial X8 Portable SSD 1TB ReviewMobile NVMePortable P1Portable SSDX8 Portable SSD
