Bigger, Faster, Stronger - but not harder
in Storage, Recent, Reviews
Crucial BX500 1TB 3D NAND SATA 2.5-Inch Internal SSD, up to 540MB/s - CT1000BX500SSD1
5. HD Tune
  • 2. Specs
  • 5. HD Tune
  • 6. ATTO Disk
  • 7. Crystal DiskMark
  • 8. AS-SSD
  • 9. IOMETER
  • 10. System Boot Time
  • 11. Real World Data Transfers
  • 12. Adobe Load Time
  • 13. VMWare Load Time
  • 14. Gaming Load Time
  • 16. Synthetic Test Results
  • 17. Real World Results
  • 18. Summary and TL;DR
  • 19. Closing Statement
Read Bandwidth
Crucial MX500 1TB 10
Write Performance
Crucial MX500 1TB 11
Just like the MX500 500GB before it, the sequential read performance of this drive is rather good bordering on great. Of course, once the pseudo-SLC write buffer is filled it will get slower but we doubt many will encounter such a scenario all that often in the real world. That is because this buffer is twice as large as the already generous 500GB’s. This certainly is how we like to see a review start and hopefully it is a sign of things to come.
5. HD Tune
  • 2. Specs
  • 5. HD Tune
  • 6. ATTO Disk
  • 8. AS-SSD
  • 9. IOMETER
Page 5 of 19
ZenFone 4 PRO Review
PNY GTX 770 Unboxing
December 8, 2013
