Ballistix Elite DDR4-3600 Review
Power and Value
in Reviews, Ram, Recent
Corsair Vengeance LPX 16GB (2 X 8GB) DDR4 3600 MHz (PC4-28800) C18 1.35V Desktop Memory - Black...
Corsair Vengeance LPX 16GB (2 X 8GB) DDR4 3600 MHz (PC4-28800) C18 1.35V Desktop Memory - Black (CMK16GX4M2D3600C18)
G.Skill Ripjaws V Series 32GB (2 x 16GB) 288-Pin SDRAM (PC4-28800) DDR4 3600 CL16-19-19-39 1.35V...
G.Skill Ripjaws V Series 32GB (2 x 16GB) 288-Pin SDRAM (PC4-28800) DDR4 3600 CL16-19-19-39 1.35V Dual Channel Desktop Memory Model F4-3600C16D-32GVKC
15. WinRAR, x264 HD (X299)
  • 5. Overclocking Performance
  • 6. Adobe Performance (Z370)
  • 7. Cinebench, Geekbench, POV-Ray (Z370)
  • 8. AC, BF 4, Crysis (Z370)
  • 9. GTA V, Metro: LL (Z370)
  • 10. WinRAR, x264 HD (Z370)
  • 11. Adobe Performance (X299)
  • 12. Cinebench, Geekbench, POV-Ray (X299)
  • 13. AC, BF 4, Crysis (X299)
  • 14. GTA V, Metro: LL (X299)
  • 15. WinRAR, x264 HD (X299)
  • 16. Score Card and Summary
  • 17. Closing Statement
winRAR Benchmark
Ballistix Elite DDR4-3600 Review 38
x264 HD Benchmark
Ballistix Elite DDR4-3600 Review 39
Page 15 of 17
Tags: BallistixBallistix EliteBallistix MemoryDDR4memorypcmrRAMreviewSilicon PowerTurbine RGBXpower
Crucial P5 Plus 2TB Review
September 23, 2021
