Zotac GTX 1070Ti Mini
Good things can come in small packages
in GPU, Recent, Reviews
ZOTAC GeForce GTX 1070 Ti MINI 8GB GDDR5 256-bit Super Compact Gaming Graphics Card IceStorm...
ZOTAC GeForce GTX 1070 Ti MINI 8GB GDDR5 256-bit Super Compact Gaming Graphics Card IceStorm Cooling, Metal Backplate, LED Lit ZT-P10710G-10P
$439.00
1 used from $439.00
as of March 20, 2026 8:43 pm
GEFORCE GTX 1070 TI Mini 8GB
$899.99
1 used from $1,029.00
$269.00
8 new from $260.00
2 used from $399.97
Last updated on March 20, 2026 8:43 pm
10. Temperature, Noise, and Power Analysis
  • 3. A Closer look
  • 12. Score Card and Summary
  • 13. Closing Statement
For all temperature testing the cards were used in an open test bed environment. Ambient temperature was kept at a constant 20°C (+/- 0.5°C) and if the ambient room temperatures rose above 21°C or dropped below 19°C at any time, all benchmarking was stopped until proper temperatures could normalize.
Zotac GTX 1070Ti Mini 50
Sound Level Test Results
While everyone “hears” noise differently there is one easy way to remove all subjectiveness and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us coloring the results and see what fans fit within your personal comfort level. Of course, we will endeavor to try and explain the various results – which are taken at a 15 inch distance from the GPU’s fan(s) – to help you gain an even better understanding of how loud a cooler’s stock fan is, but even if you discount our personal opinions, the fact remains numbers don’t lie.
Zotac GTX 1070Ti Mini 51
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes an variances that could potentially crop up because of brownouts and power spikes.
Zotac GTX 1070Ti Mini 52
For an ACX based design the EVGA GeForce GTX 1070 FTW DT does have a lot going for it. Thanks to reference stock speeds it does – relatively speaking – sip power, is a very quiet video card, and is rather pretty. On the other hand at retail prices it may not glitter like gold for you. So take its rep with a grain of salt and see if its abilities do indeed line up with what you want it to be… and go from there.
  • 3. A Closer look
Page 10 of 13
Tags: 1070tiGTXGTX 1070GTX 1070 TiGTX1070timini gtx 1070NvidiaZotacZotac GTX 1070TiZotac Mini
Crucial MX500 1TB M.2 Review
Synology DiskStation DS1621 Plus Review
Silicon Power DDR4-2400 Review
