Home Ram
Silicon Power XPower Turbine RGB DDR4-3200 Review
Putting the Budget back in RGB
in Ram, Recent, Reviews
Silicon Power DDR4 16GB (8GBx2) RGB RAM Turbine Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V...
Silicon Power DDR4 16GB (8GBx2) RGB RAM Turbine Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V UDIMM Desktop Memory Module - Low Voltage (SP016GXLZU320BDB)
Silicon Power DDR4 16GB (8GBx2) Zenith RGB RAM Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V UDIMM...
Silicon Power DDR4 16GB (8GBx2) Zenith RGB RAM Gaming 3200MHz (PC4 25600) 288-pin C16 1.35V UDIMM Desktop Memory Module - Low Voltage SP016GXLZU320BDD
10. WinRAR, x264 HD
  • 5. Overclocking Results
  • 6. Adobe Performance
  • 8. AC, BF 4, Crysis
  • 9. GTA V, Metro: LL
  • 10. WinRAR, x264 HD
winRAR Benchmark
Silicon Power XPower Turbine RGB DDR4-3200 Review 32
x264 HD Benchmark
Silicon Power XPower Turbine RGB DDR4-3200 Review 33
10. WinRAR, x264 HD
Page 10 of 12
Tags: BallistixBallistix MemoryDDR4memorypcmrRAMreviewSilicon PowerTurbine RGBXpower
