Home Ram
High Performance ram without the headache
in Ram, Recent, Reviews
10. WinRAR, x264 HD
  • 5. Overclocking
  • 6. Adobe Testing
  • 8. AC, BF 4, Crysis
  • 9. GTA V, Metro: LL
  • 10. WinRAR, x264 HD
winRAR Benchmark
Silicon Power XPower Turbine DDR4-3200 Review 26
x264 HD Benchmark
Silicon Power XPower Turbine DDR4-3200 Review 27
10. WinRAR, x264 HD
  • 5. Overclocking
  • 6. Adobe Testing
Page 10 of 12
Tags: BallistixBallistix MemoryDDR4DDR4 2400DDR4 3200DDR4 ValuememorypcmrRAMRam ReviewSilicon Power
QuadraClicks Gaming RBT Mouse Review
