Not quite ‘hard as a rock’
$141.99
8 new from $141.50
1 used from $100.83
as of March 20, 2026 6:42 pm
$209.99
5. Synthetic Performance
  • 7. Score Card
ATTO Disk Benchmark
Silicon Power Stream S07 6TB Review 20
Silicon Power Stream S07 6TB Review 21
AS-SSD
Silicon Power Stream S07 6TB Review 22
Silicon Power Stream S07 6TB Review 23
Crystal DiskMark
Silicon Power Stream S07 6TB Review 24
Silicon Power Stream S07 6TB Review 25
  • 7. Score Card
Page 5 of 8
Tags: Silicon PowerSilicon Power Stream S07
About Us
ASUS unveils Z590 ROG Maximus XII, ROG STRIX, TUF Gaming and PRIME Motherboards
January 11, 2021
T60-SFX Mini Gaming Case
August 24, 2014
