Unique Style, Unique Value
Silicon Power 1TB Rugged Portable External SSD USB 3.1 Gen 2 (USB3.2) with USB-C to USB-C/USB-A...
Silicon Power 1TB Rugged Portable External SSD USB 3.1 Gen 2 (USB3.2) with USB-C to USB-C/USB-A Cables, Ideal for PC, Mac, Xbox and PS4, PS5 Bolt B75 Pro
Silicon Power 4TB Rugged Game Drive A62 External Hard Drive PS5 Compatible
5. Synthetic Performance
  • 7. Score Card & Summary
ATTO Disk Benchmark
Silicon Power Bolt B75 Pro Review 16
Silicon Power Bolt B75 Pro Review 17
AS-SSD
Silicon Power Bolt B75 Pro Review 18
Silicon Power Bolt B75 Pro Review 19
Crystal DiskMark
Silicon Power Bolt B75 Pro Review 20
Silicon Power Bolt B75 Pro Review 21
Page 5 of 8
Tags: BX300BX500CrucialCrucial MX500Crucial SSDm2memoryMX300MX500NVMEP1P34A80reviewSilicon PowerSilicon Power Bolt B75 ProSSDSSD ReviewstorageStorage Reviewsuper fast nvmeValue SSDValue SSD Review
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
