Silicon Power 2TB Rugged Portable External Hard Drive Armor A80, Waterproof USB 3.0 for PC, Mac,...
Silicon Power 2TB Rugged Portable External Hard Drive Armor A80, Waterproof USB 3.0 for PC, Mac, Xbox and PS4, Blue
5. Synthetic Performance
  • 1. A further refinement to SP’s rugged blueprint
  • 7. Score Card and Summary
ATTO Disk Benchmark
Silicon Power Armor A65B Review 20
Silicon Power Armor A65B Review 21
AS-SSD
Silicon Power Armor A65B Review 22
Silicon Power Armor A65B Review 23
Crystal DiskMark
Silicon Power Armor A65B Review 24
Silicon Power Armor A65B Review 25
Page 5 of 8
Tags: ArmorportableSilicon Power Armor A65B ReviewSSD
Experience lightning-fast speeds with the new 13th Gen Intel Core mobile processor – the world’s fastest!
Experience lightning-fast speeds with the new 13th Gen Intel Core mobile processor - the world's fastest!
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
