PNY GeForce GTX 980 XLR8 4GB
in GPU, Reviews
PNY GeForce GTX 1660 6GB XLR8 Gaming Overclocked Edition Graphics Card (Renewed)
PNY GeForce GTX 980 4GB XLR8 OC EDITION Graphics Card
PNY GeForce GTX 980 Ti 6GB CG EDITION Graphics Card
15. PNY GeForce GTX 980 XLR8 4GB – Temperature, Noise, Power
  • 1. PNY GeForce GTX 980 XLR8 4GB – Introduction
  • 2. PNY GeForce GTX 980 XLR8 4GB – Specs and Features
  • 3. PNY GeForce GTX 980 XLR8 4GB – Closer Look
  • 4. PNY GeForce GTX 980 XLR8 4GB – Testing Methodology
  • 5. PNY GeForce GTX 980 XLR8 4GB – Synthetic Gaming Benchmarks
  • 6. PNY GeForce GTX 980 XLR8 4GB – Metro: Last Light
  • 7. PNY GeForce GTX 980 XLR8 4GB – BioShock Infinite
  • 8. PNY GeForce GTX 980 XLR8 4GB – Tomb Raider
  • 9. PNY GeForce GTX 980 XLR8 4GB – Batman Arkham Origins
  • 10. PNY GeForce GTX 980 XLR8 4GB – Real World In-Game Explained
  • 11. PNY GeForce GTX 980 XLR8 4GB – Battlefield 4
  • 12. PNY GeForce GTX 980 XLR8 4GB – Assassins Creed: Black Flag
  • 13. PNY GeForce GTX 980 XLR8 4GB – Call of Duty: Ghosts
  • 14. PNY GeForce GTX 980 XLR8 4GB – Crysis 3
  • 15. PNY GeForce GTX 980 XLR8 4GB – Temperature, Noise, Power
  • 16. PNY GeForce GTX 980 XLR8 4GB – Overclocking
  • 17. PNY GeForce GTX 980 XLR8 4GB – Performance Summart and TL;DR
  • 18. PNY GeForce GTX 980 XLR8 4GB – Score Card and Summary
  • 19. PNY GeForce GTX 980 XLR8 4GB – Closing Statement
Temperature, Noise, and Power Analysis
heat
This card is a damn cool running card for an enthusiast grade GPU! Of course some of its great cool running abilities come from the fact that its stock heatsink and fan are big and more than enough to keep a 165 watt TDP processor cool. This explains why the idle temperatures are so amazingly low. We can just image what they would have been if this video card used one PNY’s stellar custom cooling solutions!
Sound Level Test Results
For Idle tests, we let the system idle at the Windows 7 desktop for 25 minutes and recorded the peak dB.
noise
For an enthusiast grade video card these results are damn impressive. Unfortunately, the PNY GTX 980 XLR8 is still a blower based design and as such will not be as quiet as could possibly be. However, it is worth noting that these results are absolute worst case scenario results and in more realistic gaming scenarios this card was as quiet as a church mouse. All in all, this is one of the best blower style GPU cards we have seen, but it could have been even better if PNY had opted for one of their custom coolers.
System Power Consumption
power
As expected this card is a power miser. Will it save enough power to make it a worthwhile upgrade from an 780Ti? No. Unless you are paying 50 cents a KW/hour you will never save enough to make it worth it -as you will upgrade to the next generation long before the breakeven point!
Page 15 of 19
Dragon Age: Inquisition
