in GPU, Reviews
MSI Gaming AMD Radeon RX 6600 XT 128-bit 8GB GDDR6 DP/HDMI Dual Torx Fans FreeSync DirectX 12 VR...
MSI Gaming AMD Radeon RX 6600 XT 128-bit 8GB GDDR6 DP/HDMI Dual Torx Fans FreeSync DirectX 12 VR Ready OC Graphics Card (RX 6600 XT MECH 2X 8G OC)
MSI Gaming AMD Radeon RX 6600 XT 8GB GDDR6 128-Bit HDMI/DP Torx Fan RGB Graphics Card (RX 6600 XT...
MSI Gaming AMD Radeon RX 6600 XT 8GB GDDR6 128-Bit HDMI/DP Torx Fan RGB Graphics Card (RX 6600 XT Gaming X 8G)
MSI Gaming AMD Radeon RX 6600 XT 8GB GDDR6 128-bit HDMI/DP 2602 MHz Boost Clock FreeSync DirectX...
MSI Gaming AMD Radeon RX 6600 XT 8GB GDDR6 128-bit HDMI/DP 2602 MHz Boost Clock FreeSync DirectX 12 VR Ready OC Graphics Card (RX 6600 XT MECH 2X 8G OCV1)
13. Temperature, Noise, and Power Analysis
  • 1.   A Good Design Handicapped by Terrible AMD Decisions
  • 5. AC: Odyssey, Battlefield 1
  • 6. Battlefield 5, CoD: BO5
  • 7. Crysis 3, Far Cry 5
  • 8. Far Cry New Dawn, GTA V
  • 9. Hitman 2, Metro Exodus
  • 10. RAGE 2, Shadow of Tomb Raider
  • 11. Strange Brigade, The Division 2
  • 12. Watch Dogs: Legion, Witcher 3
  • 13. Temperature, Noise, and Power Analysis
  • 14. Overclocking Results
  • 16. Closing Thoughts
MSI Radeon RX 6600 XT Gaming X Review 54
Sound Level Test Results
MSI Radeon RX 6600 XT Gaming X Review 55
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potential crop up because of brownouts and power spikes.
MSI Radeon RX 6600 XT Gaming X Review 56
Page 13 of 16
Tags: 6600xtAMDGPUMSIMSI Radeon RX 6600XT Gaming Xradeon
Seagate FireCuda 2TB Review
