LaCie Rugged SSD Pro Review
in Storage, Reviews
LaCie Rugged SSD Pro 2TB Solid State Drive — USB-C Thunderbolt 3, Drop Shock Dust Water...
LaCie Rugged SSD Pro 2TB Solid State Drive — USB-C Thunderbolt 3, Drop Shock Dust Water Resistant, for Mac and PC Computer Desktop Laptop, 1 Mo Adobe CC (STHZ2000800)
LaCie Rugged Mini 5TB External Hard Drive Portable HDD – USB 3.0/2.0 Compatible, Drop Shock Dust...
LaCie Rugged Mini 5TB External Hard Drive Portable HDD – USB 3.0/2.0 Compatible, Drop Shock Dust Rain Resistant Shuttle Drive, For Mac And Computer Desktop Workstation PC Laptop (STJJ5000400)
LaCie Rugged Secure 2TB External Hard Drive Portable HDD – USB-C USB 3.0 Drop Shock Dust Rain...
LaCie Rugged Secure 2TB External Hard Drive Portable HDD – USB-C USB 3.0 Drop Shock Dust Rain Resistant Computer Desktop Workstation Laptop Hardware Encryption, 1 Month Adobe CC (STFR2000403)
5. Synthetic Performance
  • 7. Score Card and Summary
ATTO Disk Benchmark
LaCie Rugged SSD Pro Review 17
LaCie Rugged SSD Pro Review 18
AS-SSD
LaCie Rugged SSD Pro Review 19
LaCie Rugged SSD Pro Review 20
Crystal DiskMark
LaCie Rugged SSD Pro Review 21
LaCie Rugged SSD Pro Review 22
Page 5 of 8
Tags: External StorageLaCieLaCie Rugged BOSS SSDLaCie Rugged SSD Promedia storageprofessional ssdprofessional storageruggedSeagate BarraCuda SATA 1TB SSDSSDstorage
May 9, 2014
