LaCie 2Big RAID Review
LaCie 2big RAID 8TB External Hard Drive Desktop HDD – USB-C, 7200 RPM Enterprise Class Drives,...
LaCie 2big RAID 8TB External Hard Drive Desktop HDD – USB-C, 7200 RPM Enterprise Class Drives, for Mac and PC Desktop, Rescue Services (STHJ8000800)
LaCie 2big RAID, 18TB, External Hard Drive Desktop, USB-C, 7200 RPM Enterprise Class Drives, for...
LaCie 2big RAID, 18TB, External Hard Drive Desktop, USB-C, 7200 RPM Enterprise Class Drives, for Mac and PC Desktop, 5 Years Rescue Services (STHJ28000800)
LaCie 2big Dock RAID 16TB External RAID Hard Drive HDD with SD Card CF Card Slots, for Mac and PC...
LaCie 2big Dock RAID 16TB External RAID Hard Drive HDD with SD Card CF Card Slots, for Mac and PC Desktop Data Redundancy Thunderbolt 3 USB-C USB 3.0, 1 Month Adobe CC, Data Recovery (STGB16000400)
6. Synthetic Performance
  • 1. 2Big 2Fail 2Impress
  • 3. Closer Look (external)
  • 4. Closer Look (internals)
  • 6. Synthetic Performance
  • 7. Real World Performance
ATTO Disk Benchmark
LaCie 2Big RAID Review 28
LaCie 2Big RAID Review 29
AS-SSD
LaCie 2Big RAID Review 30
LaCie 2Big RAID Review 31
Crystal DiskMark
LaCie 2Big RAID Review 32
LaCie 2Big RAID Review 33
Page 6 of 9
Tags: 2bigLaCieLaCie 1BigLaCie 2Big RAIDraid
Divoom Tivoo Max Review
