Crucial P1 RAID Review
Even better value when RAID’ed
in Storage, Recent, Reviews
Crucial P3 1TB PCIe Gen3 3D NAND NVMe M.2 SSD, up to 3500MB/s - CT1000P3SSD8
9. Boot Time & Real World Data Transfer Performance
  • 3. Primer on QLC-NAND
  • 4. The differences between the 500 and 1TB options
  • 6. Sequential R/W
  • 13. Real World Results
  • 14. Heat Impact on Performance
  • 16. Closing Thoughts
System Boot Time
Please note: Unlike all other RAID tests we are not using Windows 10 ‘software RAID’. Instead this test, and this test only, uses motherboard RAID in order to create a bootable RAID array and load Windows on to it. To do this you will obviously have to manually install the Intel RST driver so the array is seen during installation. Needless to say RAID is not for everyone.
Crucial P1 RAID Review 28
Real World Data Transfers
Crucial P1 RAID Review 29
Crucial P1 RAID Review 30
  • 6. Sequential R/W
Page 9 of 16
Tags: BallistixBallistix MemoryBX300BX500CrucialCrucial MX500Crucial SSDm2memoryMX300MX500reviewSSDSSD ReviewstorageStorage ReviewValue SSDValue SSD Review
Silicon Power XS70 1TB Review
