Crucial P1 RAID Review
Even better value when RAID’ed
in Storage, Recent, Reviews
Crucial P3 1TB PCIe Gen3 3D NAND NVMe M.2 SSD, up to 3500MB/s - CT1000P3SSD8
14. Heat Impact on Performance
  • 3. Primer on QLC-NAND
  • 4. The differences between the 500 and 1TB options
  • 6. Sequential R/W
  • 13. Real World Results
  • 14. Heat Impact on Performance
  • 16. Closing Thoughts
To investigate the impact has on overall performance we have used a slightly modified version of our previous IOMeter test. Instead of doing one-lump sum results we have taken a different approach. This time we will be running two separate tests. The first is sequential write performance at a queue depth of 1. The second is a sequential read performance at a queue depth of one. Each test is run for ten minutes and each cycle is repeated four times. The averages for each data point are used.
In each chart we have included both passive and actively cooled performance results. The passive is with M.2 installed in open test bed with no cooling and underneath a large (and hot running) video card. The active is the same M.2 but with it installed in a PCIe adapter card w/ heatsink and active cooling via a 120mm fan. This represents worst and best case scenarios, with most systems falling somewhere in the middle of these two extremes.
Crucial P1 RAID Review 39
Crucial P1 RAID Review 40
Crucial P1 RAID Review 41
Crucial P1 RAID Review 42
As you can see both drives have excellent read performance even under… ‘adverse conditions’. The same is not true of write performance. Basically, once the controller senses temperatures of about 60-degrees Celsius it throttles performance down to essentially SATA levels. Diving down a bit deeper the 500GB is slower in read and write performance… and in and out of throttled conditions. The variance is also a touch greater with a less ‘clean’ line. This is because the 500GB is working hard with less pSLC buffer, less RAM, and generally less everything. We doubt many would notice a difference but there is one. Of course, if you were to double the number of drives the overall performance – even in throttled mode – is also doubled. What this means is two 500GB capacity P1 drives would be much better than one 1TB if your system is not optimally configured for keeping M.2 drives cool. I.E. Same price, much better performance.
  • 6. Sequential R/W
Page 14 of 16
Tags: BallistixBallistix MemoryBX300BX500CrucialCrucial MX500Crucial SSDm2memoryMX300MX500reviewSSDSSD ReviewstorageStorage ReviewValue SSDValue SSD Review
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
