Zotac RTX 3070 AMP Holo Review
ZOTAC GeForce RTX™ 3070 Ti AMP Holo 8GB GDDR6X 256-bit 19 Gbps PCIE 4.0 Gaming Graphics Card,...
ZOTAC GeForce RTX™ 3070 Ti AMP Holo 8GB GDDR6X 256-bit 19 Gbps PCIE 4.0 Gaming Graphics Card, HoloBlack, IceStorm 2.0 Advanced Cooling, Spectra 2.0 RGB Lighting, ZT-A30710F-10P
ZOTAC GAMING GeForce RTX 3070 AMP Holo 8GB GDDR6 256-bit 14 Gbps PCIE 4.0 Gaming Graphics Card
15. Temperature, Noise, and Power Analysis
  • 1. Gorgeous Gaming Goodness
  • 7. Overclocking Results
  • 8. AC: Origins, AC: Odyssey
  • 9. Battlefield 1, Battlefield 5
  • 10. Borderlands 3, CoD: WW2, Crysis 3
  • 11. Far Cry 5, FC: New Dawn, GTA V
  • 12. Hitman 2, Metro Exodus, RAGE 2
  • 13. RDR 2, Shadow of Tomb Raider
  • 14. Strange Brigade, The Division 2, Witcher 3
  • 16. Score Card and Summary
  • 17. Closing Thoughts
Zotac RTX 3070 AMP Holo Review 86
Sound Level Test Results
Zotac RTX 3070 AMP Holo Review 87
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potential crop up because of brownouts and power spikes.
Zotac RTX 3070 AMP Holo Review 88
Page 15 of 17
Tags: Graphics CardRTX 3070video cardZotacZotac RTX 3070 AMP HoloBlack
TourBox 2020 Review
TourBox 2020 Review
