Performance and a Reasonable Price
in GPU, Recent, Reviews
GEFORCE GTX 1070 TI AMP Extreme
ZOTAC GeForce GTX 1080 Ti AMP Extreme Core Edition 11GB GDDR5X 352-bit PCIe 3.0 Gaming Graphics...
ZOTAC GeForce GTX 1080 Ti AMP Extreme Core Edition 11GB GDDR5X 352-bit PCIe 3.0 Gaming Graphics Card VR Ready (ZT-P10810F-10P)
ZOTAC GeForce GTX 980Ti AMP! Extreme 6GB ZT-90505-10P
5. Overclocking and Mining Results
  • 3. Closer look
  • 6. Syndicate, Batman: AK, BF 4
  • 8. GTA V, Hitman, Rise of Tomb Raider
  • 10. Strange Brigade, Battlefield 1, Shadow of the Tomb Raider
  • 11. Temperature, Noise, and Power Analysis
  • 12. Performance Summary and TL;DR
  • 13. Score Card and Summary
  • 14. Closing Thoughts
Zotac AMP Extreme GTX 1070 Review 18
Zotac AMP Extreme GTX 1070 Review 19
Zotac AMP Extreme GTX 1070 Review 20
Zotac AMP Extreme GTX 1070 Review 21
Zotac AMP Extreme GTX 1070 Review 22
Let’s start with what we dislike with this card when it comes to overclocking and its potential… and… we are done.
For experienced enthusiasts there is nothing major to dislike about this card when it comes to overclocking. For a NVIDIA GTX 1070 class card this is about as good as it gets. No it does not use a fancy counter-rotating central fan. No it does not come with the ability to push past the NVIDIA dictate on how far you can push the voltages. Neither really matter… as all GTX 1070s have this limitation and this card simply does not need advanced rotational fans. Instead it comes with three of some of the best fans we have tested to date. Their ability to push air through a massive heatsink is nearly unmatched. Even then to find its equal you will have to spend a lot more than what ZOTAC sells their premium version for. As when pushed to the limits of sanity this card runs cool and quiet. So much so it is not even in the same league as the standard AMP! edition.
This of course is a double-edged sword. Much like the Gigabyte AORUS if you are not careful you blow well past sane and go all the way to plaid. Even then temperatures and noises are still well within check… the first thing you will notice is that in a year or less that something dies from all the insane voltage you are pushing to it. Most likely the GDDR5 RAM ICs. This is slightly less likely to happen, as unlike Gigabyte, ZOTAC has carefully binned the RAM ICs so they are some of the best you can find.
This of course is no guarantee that it won’t happen at some point, but based on personal experience it will happen later than it will with ASUS (we have killed two STRIX OC’s so far to zero for ZOTAC). This really is the only issue we have with this card as it really is not a great choice for first time / novice overclocking enthusiasts. Much like that one friend who thinks it’s hilarious when you get blind drunk… this card will never, ever go ‘nah brah you should stop now’. Instead it is right there egging you on trying to get another percent or two higher overclock. Yes, it simply is overbuilt for novices and will give almost no indication that the core or RAM is being pushed far beyond sensible long-term limits.
So with this in mind our results are conservative, however they are the highest levels we have gotten with a GTX 1070 that we feel 100% comfortable using long term. To be precise we boosted the core from 1835 to 2092 MHz (which it stays at 100% of the time when under load), the GDDR5 from 8.2GHZ to 8824 (effective) MHz, and generally created a GTX 1070 that acts a heck of a lot more like a good GTX 1070Ti than the GTX 1070 really is.
  • 3. Closer look
Page 5 of 14
Tags: AMDASUS STRIX GTX 1070 08GEVGA GTX 1070 FTW DTGeforceGTX 1070GTX 1070tigtx1070Nvidiavideo cardvideo card reviewZotac
HyperX Cloud Mix Review
July 19, 2016
