Seagate SkyHawk 14TB Review
Master of Surveillance but not right for everyone
Seagate Exos X16 14TB 7200 RPM SATA 6Gb/s 256MB Cache 3.5-Inch Internal Data Center HDD...
Seagate Exos X16 14TB 7200 RPM SATA 6Gb/s 256MB Cache 3.5-Inch Internal Data Center HDD Enterprise Hard Drive (ST14000NM001G)
SEAGATE ST4000VX007 Skyhawk 4TB Surveillance Hard SATA 6Gb/s 64MB Cache 3.5-Inch Internal...
SEAGATE ST4000VX007 Skyhawk 4TB Surveillance Hard SATA 6Gb/s 64MB Cache 3.5-Inch Internal Drive-Frustration Free Packaging (ST4000VXZ07)
11. Boot time and Data Transfer
  • 5. Closer Look
  • 16.   Closing Statement
System Boot Time
Seagate SkyHawk 14TB Review 34
Real World Data Transfers
Seagate SkyHawk 14TB Review 35
Seagate SkyHawk 14TB Review 36
  • 5. Closer Look
Page 11 of 16
Tags: SeagateSeagate SkyHawk 14TBSkyHawkSkyHawk 14TB
