Home Recent
Seagate Exos M 30TB Review
When you need a bigger HAMR
in Recent, Reviews, Storage
$699.99
as of March 23, 2026 9:12 pm
12. Crystal Diskmark & AS-SSD
  • 3. What Is HAMR? A Primer.
  • 10. Sequential Performance
  • 11. ATTO Disk Benchmark
  • 13. IOMeter
  • 15. Adobe & VMWare
  • 16. Game Load Time
  • 18. Score Card and Summary
  • 19. Closing Statement
Crystal DiskMark
Crystal DiskMark is designed to quickly test the performance of your hard drives. Currently, the program allows you to measure sequential and random read/write speeds; and allows you to set the number of test iterations to run. We left the number of tests at 5 and size at 100MB.
Seagate Exos M 30TB Review 53
Seagate Exos M 30TB Review 54
AS-SSD
AS-SSD is designed to quickly test the performance of your drives. Currently, the program allows for measuring sequential and small 4K read/write speeds as well as 4K file speed at a queue depth of 6. While its primary goal is to accurately test Solid State Drives, it does equally well on all storage mediums it just takes longer to run each test as each test reads or writes 1GB of data.
Seagate Exos M 30TB Review 55
Seagate Exos M 30TB Review 56
  • 13. IOMeter
Page 12 of 19
MSI PC Build Guide Review
Intel Reclaiming Top Crown?
July 27, 2021
