MSI DataMAG 20Gbps 1TB Review
Flawed, but worth your time
MSI DATAMAG 20Gbps 1TB Portable SSD, 1TB External Solid State Drive, Speeds Up to 1600MB/s,...
MSI DATAMAG 20Gbps 1TB Portable SSD, 1TB External Solid State Drive, Speeds Up to 1600MB/s, USB-C, Reliable Storage for Gaming, Students, Professionals, Black
MSI DATAMAG 20Gbps 2TB Portable SSD, 2TB External Solid State Drive, Speeds Up to 1600MB/s,...
MSI DATAMAG 20Gbps 2TB Portable SSD, 2TB External Solid State Drive, Speeds Up to 1600MB/s, USB-C, Reliable Storage for Gaming, Students, Professionals, Black
5. Synthetic Performance
  • 7. Score Card & Summary
ATTO Disk Benchmark
MSI DataMAG 20Gbps 1TB Review 22
MSI DataMAG 20Gbps 1TB Review 23
AS-SSD
MSI DataMAG 20Gbps 1TB Review 24
MSI DataMAG 20Gbps 1TB Review 25
Crystal DiskMark
MSI DataMAG 20Gbps 1TB Review 26
MSI DataMAG 20Gbps 1TB Review 27
Page 5 of 8
Tags: Affordable StorageDataMagDataMag 20Gbps 1TBDiamond in the RoughExternal SSDHeat Pad IssueLaCie CompetitorMSINext-Gen SSDPerformance SSDPhisonprofessional storageSSD CoolingStorage DevicesTech Review
