LaCie Rugged SSD 1TB Review
Serious performance, Series protection, not so serious color scheme
LaCie Rugged SSD 1TB Solid State Drive — USB-C USB 3.2 NVMe speeds up to 1050MB/s, IP67 Water...
LaCie Rugged SSD 1TB Solid State Drive — USB-C USB 3.2 NVMe speeds up to 1050MB/s, IP67 Water Resistant, 3m Drop resistant, Encryption, 5-year Warranty with Data Recovery, 1 Mo Adobe CC (STHR1000800)
LaCie Mobile SSD 1TB High Performance External SSD USB-C with 1 Month of Adobe Creative Cloud
LaCie Rugged SSD 1TB, External SSD, USB-C, Thunderbolt 3, Extreme Water and 3m Drop Resistance,...
LaCie Rugged SSD 1TB, External SSD, USB-C, Thunderbolt 3, Extreme Water and 3m Drop Resistance, Mac, PC, incl. USB-C w/o USB-A Cable, 5 Year Rescue Services (STHR1000800)
5. Synthetic Performance
  • 7. Score Card and Summary
ATTO Disk Benchmark
LaCie Rugged SSD 1TB Review 21
LaCie Rugged SSD 1TB Review 22
AS-SSD
LaCie Rugged SSD 1TB Review 23
LaCie Rugged SSD 1TB Review 24
Crystal DiskMark
LaCie Rugged SSD 1TB Review 25
LaCie Rugged SSD 1TB Review 26
Page 5 of 8
Tags: LaCie RuggedLaCie Rugged SSD 1TB ReviewOne Touch SSDPortable SSDPortable StorageSeagateSSD
CES 2020 With Asus
CES 2020 With Asus
Bitfenix Shadow Review
June 21, 2014
