Gigabyte Aorus WaterForce 280 Review
AORUS WATERFORCE X 280 AIO Liquid CPU Cooler, Rotatable Circular LCD Display with Micro SD...
AORUS WATERFORCE X 280 AIO Liquid CPU Cooler, Rotatable Circular LCD Display with Micro SD Support, 280mm Radiator with 2x140mm Low Noise ARGB Fans, Compatible with Intel LGA1700
5. Testing Methodology
  • 1. Asetek meets Innovation
  • 4. Installation & Issues
While there are many, many ways of properly and efficiently testing CPU cooling solutions not every method will offer useful information for all potential buyers. Some consumers care more about noise than shear performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-round design. Further complicating things is results on consumer Intel systems do not necessarily translate to bigger “HEDT” CPU based testbeds (and vice versa)… as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
This different approach starts with testing on two testbeds and not just one. The first is an Intel 11th generation Core i9-11900K CPU. This CPU’s thermal characteristics make it a good representation of “worst case scenario’ for what most users will experience. For power users who like HEDT/workstation/etcs systems we have opted for a Core i9 10980XE based system. Both are tested at stock and a moderately stressful overlock.
Consumer Testbed:
Processor: Intel Core i9-10900K
Motherboard: ASUS ROG Maximus XIII Hero Z590
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 10 Professional
HEDT Testbed:
Processor: Intel Core i9-10980XE
Motherboard: ASUS TUF MARK X299
Cooling: Various
Page 5 of 9
Tags: AIOAorus waterforcecpu coolingx280
TerraMaster F2-210 Review
