  • 4. BiCS 3 primer
System Boot Time
Gigabyte Aorus RGB NVMe 256GB M.2 Review 32
Real World Data Transfers
Gigabyte Aorus RGB NVMe 256GB M.2 Review 33
Gigabyte Aorus RGB NVMe 256GB M.2 Review 34
  • 4. BiCS 3 primer
Page 10 of 16
May 9, 2014
