Seagate FireCuda 510 1TB SSD Review
in Storage, Recent, Reviews
Seagate FireCuda 510 1TB Performance Internal Solid State Drive SSD - M.2 PCIe Gen3 x4 NVMe 1.3...
Seagate FireCuda 510 1TB Performance Internal Solid State Drive SSD - M.2 PCIe Gen3 x4 NVMe 1.3 for Gaming PC Gaming Laptop Desktop with Rescue Services (ZP1000GM3A011)
Seagate FireCuda 510 1TB Performance Internal Solid State Drive SSD PCIe Gen3 x4 NVMe 1.3 for...
Seagate FireCuda 510 1TB Performance Internal Solid State Drive SSD PCIe Gen3 x4 NVMe 1.3 for Gaming PC Gaming Laptop Desktop (ZP1000GM30011)
Seagate Firecuda 510 500GB Performance Internal Solid State Drive SSD PCIe Gen3 X4 NVMe 1.3 for...
Seagate Firecuda 510 500GB Performance Internal Solid State Drive SSD PCIe Gen3 X4 NVMe 1.3 for Gaming PC Gaming Laptop Desktop - 3-year Rescue Service (ZP500GM3A001)
16. Temperature’s Impact on Performance
  • 4. BiCS 3 primer
  • 14. Synthetic Test Results
  • 15. Real World Results
  • 16. Temperature’s Impact on Performance
  • 17. Score Card and Summary
  • 18. Closing Statement
To investigate the impact has on overall performance we have used a slightly modified version of our standard IOMeter test. Precisely we have run 8 test runs per device (1,4,16,64,128,256 queue depth) each test having 8 parts, each part lasting 60 min w/ an additional 20 second ramp up. The 6 subparts were set to run 100% random, 75% read 25% write; testing 512b, 4k,8k,16k,32k,64k size chunks of data. When each test is finished IOMeter spits out a report, in that reports each of the 6 subtests are given a score in I/Os per second. The results for the first two test runs/hours are discarded and only the last 6 run reports are averaged.
The two different result for each device in the chart are the results of the above test run with and without additional cooling. For “no cooling” the M.2 device in it’s out of the box configuration is installed in open test bed with no cooling and underneath a large (and hot running) video card. For “active cooling” results the same device has been installed in a PCIe adapter card w/ heatsink and active cooling via a 120mm fan pushing air over both sides of the M.2 card. These results represent the best- and worst-case scenario for any M.2 solid state drive. They are not indicative of average or typical real-world performance. Simply the best and worst a drive has to offer.
  • 4. BiCS 3 primer
Page 16 of 18
Tags: Exos ReviewExos x16FireCudaIronwolfIronWolf ReviewPCmasterracepcmrreviewSeagateSeagate BarracudaSeagate BarraCuda 510Seagate BarraCuda 510 ReviewSeagate Exos X16 ReviewSeagate FireCuda 510 1TB SSDSeagate IronWolf 110 SSDSeagate IronWolf 110 SSD ReviewSeagate NVMestorageStorage Review
Acronis True Image 2020 Review
