EVGA GTX 1070Ti SuperClocked Black Edition
The dark horse pick
in GPU, Recent, Reviews
EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition, 8GB GDDR5, LED, DX12 OSD Support (PXOC)...
EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition, 8GB GDDR5, LED, DX12 OSD Support (PXOC) 08G-P4-5173-KR (Renewed)
EVGA GeForce GTX 1080 Ti SC Black Edition Gaming, 11GB GDDR5X, iCX Cooler & LED, Optimized...
EVGA GeForce GTX 1080 Ti SC Black Edition Gaming, 11GB GDDR5X, iCX Cooler & LED, Optimized Airflow Design, Interlaced Pin Fin Graphics Card 11G-P4-6393-KR (Renewed)
EVGA GeForce GTX 1660 SC Ultra Gaming, 06G-P4-1067-KR, 6GB GDDR5, Dual Fan
10. Temperature, Noise, and Power Analysis
  • 3. A Closer Look
  • 6. AC:Syndicate, Batman: AK, BF 4
  • 12. Score Card and Summary
  • 13. Closing Statement
EVGA GTX 1070Ti SuperClocked Black Edition 44
Sound Level Test Results
EVGA GTX 1070Ti SuperClocked Black Edition 45
System Power Consumption
EVGA GTX 1070Ti SuperClocked Black Edition 46
Obviously EVGA’s newer ICX cooling solution is more optimal than the older ACX design. Water is wet, the sky is blue and technology is always marching on. That is not the same as saying the EVGA GeForce GTX 1070Ti SC BE and its ACX cooler is bad. Its just that the newer ICX is so much better.
Compared to most 1070Ti class cards the EVGA GeForce GTX 1070Ti SC BE is pretty darn good. Not the best, but certainly above average. Use this negative perception to your advantage… and be on the look out for killer deals of this ‘little brother’ and let others spend more for the FTW2. The difference really is not going to be worth it to most people. Only those who really care about a silent video card solution will care – and should shell out the extra coin for the FTW2. Everyone else will still be either very satisfied or at least satisfied with the savings their new purchase netted them.
  • 3. A Closer Look
Page 10 of 13
Tags: EVGAEVGA SC 1070tiGPUGPU ReviewGraphics Card ReviewGTXGTX 1070GTX 1070 TiGTX1070ti
EVGA GTX 1070 FTW DT Review
