Crucial MX500 4TB Review
Crucial MX500 4TB 3D NAND SATA 2.5 Inch Internal SSD, up to 560MB/s - CT4000MX500SSD1
Crucial P3 Plus 4TB PCIe Gen4 3D NAND NVMe M.2 SSD, up to 5000MB/s - CT4000P3PSSD8
3. Replacement Gate Technology Primer
  • 1. At what point should a refreshed model get a new model name?
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Score Card and Summary
  • 14. Closing Statement
Crucial MX500 4TB Review 6
For those that have read our previous Solid State Drive reviews the easiest way to imagine what Micron has done in order to create their ‘Replacement Gate’ NAND is to imagine the melding of typical Charge Trap design with earlier Micron CuA NAND logic layout. Then imagine it bigger, stronger and better than other NAND designs available on the market today. Simply put, it is a new spin on Charge Trap NAND theory and design… and not an entirely new approach to NAND design.
Crucial MX500 4TB Review 7
With SLC NAND, a cell that is left alone will not lose all that much voltage and is fairly stable for months between power on states. However, as each NAND cell can only store 1 bit it is rather expensive to create say a 1TB Solid State Drive, and scaling up beyond 1TB requires a lot of NAND chips. Even layering NAND cells on top of NAND cells on top of NAND cells the resulting footprint would be rather large. This combination is why Multi-Level Cell NAND was created and doubled a NAND cell’s storage capacity from 1 bit to 2 bits. It did this by adding more voltage resistance points between ‘full’ and ‘empty’. So instead of two states there was now four states: 0, 0.25, 0.5, 0.75, and 1. This certainly increased storage density, and decreased cost of manufacture to hit a given storage capacity, but at the same time made the self-discharging of NAND a greater issue – as lot less of a voltage change can indeed impact two bits of data. This is why MLC is not as stable as SLC and has to be refreshed / rewritten more often (aka ‘internal housecleaning’).
Crucial MX500 4TB Review 8
Crucial MX500 4TB Review 9
Controller and storage companies are also aware of this issue and include even more ‘replacement cells’ (aka ‘over-provisioning’ and why your 256GB drive may be seen as a 240GB drive) but also use slower / gentler write algorithms to reduce this damage (typically 8 voltage steps or more). In simplistic terms this means they write to the NAND using less voltage but over a longer period of time. This does reduce cell damage, but at the cost of write performance. To overcome this side effect, the controller will pretend a given chunk of TLC NAND is SLC NAND and only store two charge states instead of eight (or 16 in the case of QLC) per cell. This allows those cells to continue being used long after the amount of damage to the gate would result in random bit changes if eight (or more) states were needed. This pseudo-SLC is then used for real time writes as a buffer and is called different things by different manufactures. For example, Crucial calls it “Dynamic Write Acceleration”.
Sadly, including more backup NAND cells and / or lowering the voltage applied does nothing for charge coupling. This rare event happens when the fracture is close enough to a neighboring NAND cell that the electrons can jump from one cell to another creating a quasi-bridge between the cells. This in turn can randomly impact multiple cells worth of data and do so silently – with the controller only knowing about it when it checks the state of the cells vs. what they were supposed to be. To visualize this imagine sorting your spare change into cups that are touching one another… and a quarter bounces off the lip and ends up in the dime cup. Both cups total amount will be off, and you will not know they are off until you count both cups.
Crucial MX500 4TB Review 10
These are all well-known issues. Issues that have been known for decades. While Samsung and Toshiba opted to change the very foundation of how their NAND transistors work… Micron and Intel opted to increase the size and rearrange their cell layout to help reduce them. Put another way, they decided to kick the can down the road. The upside is the CMOS under Array (CuA) design was created. One where the interconnects are much like ‘elevators’ in an apartment building (at the ends of the ‘hallways’) and the logic hardware is under the NAND transistor array (think ‘basement’ in an apartment building). This layout helps (to somewhat) alleviate heat buildup by moving the potential hotter running interconnects closer to the edges of the NAND block.
The downside to typical CuA NAND is twofold. Firstly, it was still FG tech based. Secondly, CuA is not exactly the most efficient layout. It does have a tendency to bottleneck slightly faster than some of the competition… and the deeper the NAND layer depth the more it is likely to occur under sustained extended loads. To help minimize this last issue, Micron has opted for a rather fast ONFI “NV-DDR3” rev 4.2 bus which can handle 1600 Mega Transfers per second. Thus CuA “Replacement Gate” has ‘hallways’ and ‘elevators’ which are 50 percent wider than the previous CuA NAND’s 800MT/s bus. This works rather well at alleviating the pressure and keeping performance in tip top shape… even under extreme conditions. Will that still be the case in the future when 200+ Layer NAND is created? No one knows. What Micron is betting on is that ONFI will to continue to increase the spec’s speed faster than their CuA’s low-level bottlenecking issue. Considering ONFI 5 standard calls for another 50 percent increase in performance (2400MT/s) time will tell if their gamble pays off or not. In the meantime, their existing Replacement Gate NAND tech is relying upon an incredibly fast bus (by today’s standards) that is more than up to the demands placed upon it.
Crucial MX500 4TB Review 11
Crucial MX500 4TB Review 12
Crucial MX500 4TB Review 13
To understand these issues, imagine the typical high end condo building. While all the condos on a given floor share the hallway, each condo has its own door and rather thick “firewalls” separating one condo from another. In Replacement Gate technology… Micron has clustered cells into groups. With a nonconductive layer of silicon nitride surrounding the insulator gates. This not only allows for increased performance (~35 percent over their previous gen), but a noticeable reduction in footprint (this 176Layer NAND takes up about the same room as their 64Layer FG NAND did). It also promises to be even more resilient to charge coupling issues – further making it even more reliable – when compared to standard CT NAND designs. These promises remain unknowns and only time will tell if Micron has indeed created a better design, but it certainly shows potential.
Without going into white paper levels of detail all the above is the simplified basics on what makes Replacement Gate Technology ‘tick’ and why Micron has indeed not only achieved parity but arguably surpassed the competition.
  • 8. IOMeter
Page 3 of 14
Tags: 4tbCrucialCrucial MX500 4TB Review
Intel Core i9 12900K and i5 12600K Review
