Keeper of the Crown
7. Testing Methodology
  • 1.  Introduction
  • 6. Installation Issues
  • 8. Performance Results
  • 10. Score Card and Summary
  • 11. Closing Statement
While there are many, many ways of properly and efficiently testing CPU cooling solutions, not every method will offer useful information for all potential buyers. Some consumers care more about noise than sheer performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-round design. Further complicating things is that results on consumer Intel systems do not necessarily translate to AMD CPU-based testbeds (and vice versa)… as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
To this end, we are not just going to present our readers with an overly simplified result and call it good enough. Instead, we are going to do our best to provide you with as much data as possible so that you can make an informed decision based on what you consider to be important.
This different approach starts with testing on two testbeds and not just one. The first is an Intel 13th-generation Core i9-13900K CPU. This CPU’s thermal characteristics make it a good representation of what most upper-mainstream users will experience. For AMD fans, we have an older Zen 3 Ryzen 9 5950X processor. A processor that just does not like to run cool.
Further helping to give as clear a picture of a given cooler’s real-world performance, we will also be testing a test sample with the stock number of fans (i.e. whatever number is included in the box), and (when possible) the maximum number of fans. For most air-based coolers, this means one fan for stock, and two to three for maximum results; whereas with water-based, stock could be one to three, and three to six for maximum.
Since not all fans are made the same, we will also be testing the review sample at various fan speeds. While many can go below 800rpms few will not spin at below this level, and fewer still do so while keeping temperatures in check. This is why we have chosen 800RPM as the minimum fan speed cut-off, and from then on we increase the rotational speed in 200 to 250 RPM increments until the fan is running at ‘full speed’. This can vary from 1200 to over 3000… and will help highlight how much – or little – extra performance the increase in rotational speed brings to the table. Our personal cutoff for CPU temperature is 90 degrees, but to give as full a picture as possible, we have opted (when possible) for 95 °C as the cutoff, and as such, once 95-degree temperature results are reached no further results below that fan speed will be included.
The included results are the average for 20 minutes of stress testing using Aida64 and its built-in stress testing with logging feature enabled (as found under File / Preferences / Hardware Monitoring / Logging). In cases where the ‘maximum’ fan speed falls between two chart points, we will take a rounding-up approach and place the max numbers under the higher fan speed point.
To round out our testing, we have included fan noise using the stock number of fans included in the box, and at all successful rotational speed points above background noise levels. These results are taken using a professionally calibrated and NIST-certified DT-805 sound meter that is placed 24 inches away from the cooler. We then spin up or down the fan on the cooling solution while the (Intel) CPU is idling.
Intel Testbed:
Memory: Crucial Pro DDR5-5600
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 11 Professional
AMD Testbed:
Processor: AMD Ryzen 9 5950X
Cooling: Various
  • 1.  Introduction
Page 7 of 11
Previous 1234567891011 Next
ZenBook Duo 2026 Review
January 18, 2018
