ARCTIC Liquid Freezer II 420 - Multi Compatible All-in-One CPU AIO Water Cooler, Efficient PWM...
ARCTIC Liquid Freezer II 420 - Multi Compatible All-in-One CPU AIO Water Cooler, Efficient PWM Controlled Pump, Fan Speed: 200-1700 RPM (Controlled via PWM), LGA1700 compatible - Black
ARCTIC Liquid Freezer II 420 A-RGB - Multi-compatible all-in-one CPU AIO water cooler with A-RGB,...
ARCTIC Liquid Freezer II 420 A-RGB - Multi-compatible all-in-one CPU AIO water cooler with A-RGB, efficient PWM-controlled pump, fan speed: 200-1900 RPM, LGA1700 compatible - Black
$112.99
2 new from $112.99
1 used from $76.88
as of March 29, 2026 8:12 pm
ARCTIC Liquid Freezer II 420 - Multi Compatible All-in-One CPU AIO Water Cooler, Compatible with...
ARCTIC Liquid Freezer II 420 - Multi Compatible All-in-One CPU AIO Water Cooler, Compatible with Intel & AMD, Efficient PWM Controlled Pump, Fan Speed: 200-1700 RPM (Controlled via PWM) - Black
5. Testing Methodology
  • 1. A hardcore 420 That May Harsh Your Mellow
  • 4. Installation Issues
While there are many, many ways of properly and efficiently testing CPU cooling solutions not every method will offer useful information for all potential buyers. Some consumers care more about noise than shear performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-round design. Further complicating things is results on consumer Intel systems do not necessarily translate to bigger “HEDT” CPU based testbeds (and vice versa)… as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
This different approach starts with testing on two testbeds and not just one. The first is an Intel 11th generation Core i9-11900K CPU. This CPU’s thermal characteristics make it a good representation of “worst case scenario’ for what most users will experience. For power users who like HEDT/workstation/etcs systems we have opted for a Core i9 10980XE based system. Both are tested at stock and a moderately stressful overlock.
Further helping to give as clear a picture of a given cooler’s real-world performance, we also will be testing a test sample with stock number of fans (i.e. whatever number is included in the box), and (when possible) the maximum number of fans that can be mounted. For most air-based coolers this means one fan for stock, and two to three for maximum results; whereas with water-based stock it could be one or two for stock, or three to six for maximum.
Consumer Testbed:
Processor: Intel Core i9-10900K
Motherboard: ASUS ROG Maximus XIII Hero Z590
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 10 Professional
HEDT Testbed:
Processor: Intel Core i9-10980XE
Motherboard: ASUS TUF MARK X299
Cooling: Various
Page 5 of 9
Tags: ArcticArctic Liquid Freezer II 420Arctic VS Coolermastercooler
Alienware Aurora R12 Review
Corsair 5000D Review
