Home Mobile
ZenFone 4 PRO Review
ASUS' uber phone
in Mobile, Reviews
Tektide Case Compatible for Zenfone 4 Max/Zenfone 4 Max pro/Zenfone 4 Max Plus ZC554KL,...
Tektide Case Compatible for Zenfone 4 Max/Zenfone 4 Max pro/Zenfone 4 Max Plus ZC554KL, [Invisible Armor] Xtreme Slim, Clear, Soft, Lightweight, Shock Absorbing TPU Rubber Bumper Case/Back Cover
Motorola Edge | 2021 | 2-Day battery | Unlocked | Made for US | 8/256GB | 108MP Camera | Nebula Blue
DJI Mini 2 Fly More Combo – Ultralight Foldable Drone, 3-Axis Gimbal with 4K Camera, 12MP Photos,...
DJI Mini 2 Fly More Combo – Ultralight Foldable Drone, 3-Axis Gimbal with 4K Camera, 12MP Photos, 31 Mins Flight Time, OcuSync 2.0 10km HD Video Transmission, QuickShots, Gray
4. Benchmark Results
  • 4. Benchmark Results
  • 5. Closing Statement
3DMark For Android
3DMark For Android is a benchmark tool developed by Futuremark to test the performance of a Android mobile device’s graphical performance. In this instance we are using the older Ice Strom test which uses OpenGl ES 2.
ZenFone 4 PRO Review 21
AnTuTu Benchmark
AnTuTu is one of the most popular benchmark apps for Android devices. It tests many parts of your device and assigns an overall score.
ZenFone 4 PRO Review 22
Basemark OS II
Basemark OS II is a system-level All-In-One benchmarking tool designed for measuring overall performance of smartphones and tablets from all platforms, including Android, iOS and Windows phone 8. The benchmark features a comprehensive suite of tests including system, internal and external memory, graphics, web browsing, camera, battery and CPU consumption.
ZenFone 4 PRO Review 23
Battery Life
For testing the true battery life of mobile device we have used the simplest expedient possible – use them from fully charged until they turn themselves off and record the time it took. For talk time recorded this is a mix of 4G and 3G coverage. For 3D Gaming we have used Modern Combat 5: Blackout. For Internet this is a combination of YouTube, Netflix, and typical Internet surfing – including using Gmail for email. For charging the included charger was used and we timed how long it took to fully charge the battery.
ZenFone 4 PRO Review 24
ZenFone 4 PRO Review 25
GFXBench Manhattan Benchmark
GFXBench is a high-end graphics benchmark that measures mobile and desktop performance with next-gen graphics features across all platforms. As a true cross-API benchmark, GFXBench supports all the industry-standard and vendor-specific APIs including OpenGL, OpenGL ES, Vulkan, Metal, DirectX/Direct3D and DX12. It automaticaly detects the API level supported by your device and runs the relevant high-level tests. While it includes numerous tests we have focused solely in on ‘Manhattan 3’ which uses either the OpenGL ES 3.1, Desktop OpenGL, or Metal API.
ZenFone 4 PRO Review 26
JetStream Benchmark
JetStream combines a variety of JavaScript benchmarks, covering a variety of advanced workloads and programming techniques – covering classical, synthetic, and real-world examples – and reports a single score that balances them using geometric mean.
ZenFone 4 PRO Review 27
Networking Performance
For testing the networking abilities of a phone we have devised a simple test: copying 5GB of mixed sized files to and from the device over our home network. This homenetwork uses Ubiquit AC-Pro wireless access points connected to a Ubituiti EdgeRouter 8 Pro. The send/receiving device on the other end of the device is a Ryzen 7 1800X based system using an Intel 900P 280GB NVMe solid state drive.
ZenFone 4 PRO Review 28
PCMark For Android
PCMark For Android is a benchmark tool developed by Futuremark to test the performance of a Android mobile device at the system and component level. In most cases the tests in PCMark are designed to represent typical phone user workloads. In this instance we are using the Work 2.0 overall score which benchmarks overall phone performance and battery life based on everyday activities.
ZenFone 4 PRO Review 29
Page 4 of 5
Previous 12345 Next
Ballistix Tactical Tracer RGB: a new breed of LED RAM
Silicon Power XS70 1TB Review
