in Reviews, Accessories, Storage
Silicon Power 64GB 3-Pack Superior Pro Micro SDXC UHS-I (U3), V30 4K A1,Nintendo-Switch...
Silicon Power 64GB 3-Pack Superior Pro Micro SDXC UHS-I (U3), V30 4K A1,Nintendo-Switch Compatible, High Speed MicroSD Card with Adapter
Silicon Power 512GB Superior Micro SDXC UHS-I (U3), V30 4K A2, Compatible with GoPro Hero 9 High...
Silicon Power 512GB Superior Micro SDXC UHS-I (U3), V30 4K A2, Compatible with GoPro Hero 9 High Speed MicroSD Card with Adapter
SanDisk 128GB microSDXC-Card, Licensed for Nintendo-Switch - SDSQXAO-128G-GNCZN
6. Synthetic Test Results
  • 3. What is UHS-II and why should you care
  • 6. Synthetic Test Results
  • 7. Real World Test Results
For synthetic tests we have used both a Lexar WorkFlow USB 3.0 card reader as well as a ProGrade Digital USB 3.1 Gen 2 Dual-Slot Card Reader.
ATTO Disk Benchmark
SP Superior Pro micro SDXC UHS-II 12
AS-SSD
SP Superior Pro micro SDXC UHS-II 14
Crystal DiskMark
SP Superior Pro micro SDXC UHS-II 16
Page 6 of 8
Tags: lexarmicro sdSD cardSDXC UHS-IISilcon PowerSP Superior Pro micro
Silicon Power A55 M.2 1TB
