Silicon Power Superior Pro (SD)
An impressive mainstream SD Card
Silicon Power 64GB 3-Pack Superior Pro Micro SDXC UHS-I (U3), V30 4K A1,Nintendo-Switch...
Silicon Power 64GB 3-Pack Superior Pro Micro SDXC UHS-I (U3), V30 4K A1,Nintendo-Switch Compatible, High Speed MicroSD Card with Adapter
Silicon Power 512GB Superior Micro SDXC UHS-I (U3), V30 4K A2, Compatible with GoPro Hero 9 High...
Silicon Power 512GB Superior Micro SDXC UHS-I (U3), V30 4K A2, Compatible with GoPro Hero 9 High Speed MicroSD Card with Adapter
Silicon Power 2-Pack 128GB Micro SD Card U3 Nintendo-Switch Compatible, SDXC microsdxc High Speed...
Silicon Power 2-Pack 128GB Micro SD Card U3 Nintendo-Switch Compatible, SDXC microsdxc High Speed MicroSD Memory Card with Adapter
5. Synthetic Performance
  • 7. Score Card & Summary
For synthetic tests we have used a brand new Lexar WorkFlow USB 3.0 card reader. The reason for using this particular card reader is not because of any brand favoritism; rather we found it to be one of the better card readers available today.
ATTO Disk Benchmark
Silicon Power Superior Pro (SD) 9
Silicon Power Superior Pro (SD) 10
AS-SSD
Silicon Power Superior Pro (SD) 11
Silicon Power Superior Pro (SD) 12
Crystal DiskMark
Silicon Power Superior Pro (SD) 13
Silicon Power Superior Pro (SD) 14
As you can see the CFast 2.0 card simply dominates the competition and shows precisely how much performance professionals and enthusiasts will have access to once camera manufactures catch up.
Page 5 of 8
Tags: memoryreviewssdstorage
EVGA GTX 1080Ti SuperClocked
