Silicon Power PC60 Review
Cute and fairly compact
in Reviews, Recent, Storage
Silicon Power 512GB NVMe M.2 PCIe Gen3x4 2280 SSD (SP512GBP34A60M28)
$65.97
2 new from $65.97
as of March 23, 2026 7:12 pm
$99.99
2 new from $99.99
$209.99
Last updated on March 23, 2026 7:12 pm
5. Synthetic Performance
  • 7. Score Card and Summary
  • 8. Silicon Power PC60: Closing Statement
ATTO Disk Benchmark
Silicon Power PC60 Review 15
Silicon Power PC60 Review 16
AS-SSD
Silicon Power PC60 Review 17
Silicon Power PC60 Review 18
Crystal DiskMark
Silicon Power PC60 Review 19
Silicon Power PC60 Review 20
Page 5 of 8
Tags: Silicon PowerSilicon Power PC60
Silicon Power Stream S06 6TB Review
Intel Reclaiming Top Crown?
July 27, 2021
