Silicon Power A55 M.2 1TB
SATA and M.2?
5. Sequential Performance
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Score Card and Summary
  • 14. Closing Statement
Read Bandwidth
Silicon Power A55 M.2 1TB 14
Write Performance
  • 8. IOMeter
Page 5 of 14
