Seagate Exos X18 Review
11. Seagate Exos X18: Boot time and Data Transfer
  • 2. Specs
  • 5. Closer Look
System Boot Time
Seagate Exos X18 Review 36
Real World Data Transfers
Seagate Exos X18 Review 37
Seagate Exos X18 Review 38
  • 2. Specs
  • 5. Closer Look
Page 11 of 16
Tags: ExosSeagate Exos X18X18
