Home Accessories
Seagate Exos X16 Review
The Best of the Best Just Got Better
in Accessories, Recent, Reviews, Storage
Seagate Exos X16 12TB 7200 RPM 512e/4Kn SATA 6Gb/s 256MB Cache 3.5-Inch Enterprise HDD...
Seagate Exos X16 12TB 7200 RPM 512e/4Kn SATA 6Gb/s 256MB Cache 3.5-Inch Enterprise HDD (ST12000NM001G) (Renewed)
$299.00
1 used from $299.00
as of March 29, 2026 10:22 pm
Seagate Exos X16 12TB Internal Hard Drive Enterprise HDD - CMR 3.5 Inch Hyperscale SATA 6Gb/s,...
Seagate Exos X16 12TB Internal Hard Drive Enterprise HDD - CMR 3.5 Inch Hyperscale SATA 6Gb/s, 7200RPM, 512e/4Kn, 256MB Cache, Frustration Free Packaging (ST12000NM001G)
6. Sequential Performance
  • 1. The Best of the Best Just Got Better
  • 3. Multi-Tier Caching technology
Read Bandwidth
Seagate Exos X16 Review 18
Write Performance
Seagate Exos X16 Review 19
Page 6 of 15
AMD Ryzen 3000 Series
Corsair 5000D Review
