Seagate 10TB BarraCuda Pro
Redefining the term High Performance Hard Drive Review
in Reviews, Recent, Storage
Seagate BarraCuda Pro 10TB Internal Hard Drive Performance HDD – 3.5 Inch SATA 6 Gb/s 7200 RPM...
Seagate BarraCuda Pro 10TB Internal Hard Drive Performance HDD – 3.5 Inch SATA 6 Gb/s 7200 RPM 256MB Cache for Computer Desktop PC, Data Recovery (ST10000DM0004)
SEAGATE Barracuda Pro SATA HDD 10TB 7200RPM 6Gb/s 256MB Cache 3.5-Inch Internal Hard Drive for PC...
SEAGATE Barracuda Pro SATA HDD 10TB 7200RPM 6Gb/s 256MB Cache 3.5-Inch Internal Hard Drive for PC Desktop Computers System All in One Home Servers DAS (ST10000DM0004) (Renewed)
Seagate BarraCuda Pro 10TB Internal Hard Drive Performance HDD – 3.5 Inch SATA 6 Gb/s 7200 RPM 256MB Cache for Computer Desktop PC Laptop, Data Recovery – Frustration Free Packaging (ST10000DM0004)
3. Guardian Series Primer
  • 5. Closer Look
  • 7. Sequential Read/Write Results
  • 9. Crystal DiskMark and AS-SSD Results
  • 10. IOMeter Results
  • 11. OS load and Real World Results
  • 12. Adobe and VMWare Results
  • 13. Borderlands 2 and CoD Load Time Results
Seagate 10TB BarraCuda Pro 5
Before we begin a bit of background information and explanation is in order. As mentioned in the previous introduction page, Seagate has indeed gone back to the drawing board to create a new lineup meant to stem the incursion of Solid State Drives into their home turf. The end result of all their hard work, and countless man-hours of R’n’D, is the Guardian series. In the coming months we hope to show you what the others in this lineup have to offer but, in the meantime, the Guardian series is what Seagate calls their next generation series of hard drives. Each in this series has their Multi-Tier Caching Technology (MTC) tuned for different scenarios and the underlying technology does differ somewhat.
Seagate 10TB BarraCuda Pro 6
The SkyHawk is what Seagate calls their next generation home and SOHO orientated surveillance HDD series. These hard drives are tuned for low power consumption, low noise, and low IOPS scenarios – as shear performance is not really needed for recording and playback of video. What this means is instead of 7200rpm platters using Perpendicular Magnetic Recording (PMR) technology it is a 5900rpm Shingle Magnetic Recording (SMR) based system with the MTC tuned for ‘surveillance’ storage tasks. In other words, this is Seagate’s answer to Western Digital’s ‘Purple’ series. Put another way if you have never used a Purple hard drive, or own a TCP/IP based surveillance system, the SkyHawk will probably not be an optimal choice.
Seagate 10TB BarraCuda Pro 7
The IronWolf series is Seagate’s new Network Attached storage option. The standard is a PMR based drive while the IronWolf Pro ups the ante with 7200rpm spindle speed. Both have the MTC tuned for quirky rigors of being placed in a NAS appliance or RAID configuration. One of these quirks is having Time-Limited Error Recovery turned on so that the hard drive will not spend much time fixing low level errors. Instead it will tell the storage controller to handle it via parity stripe ECC. This reduces latency spikes and is perfect for RAID based storage performance. Outside of RAID though it is a less than optimal choice, but the increased vibration resistance and other features that allow for long term use in near-line and on-line storage scenarios actually does cross over nicely in HTPC territory where space is usually at a premium and HDDS are stacked in close proximity to one another.
Seagate 10TB BarraCuda Pro 8
This brings to the yeoman model of the hard disk drive portion of the Guardian series: the Seagate BarraCuda models. The standard is a 5900rpm PMR based model that is helium filled and has had the MTC tuned for the needs of the homes consumer. The Pro variant ups the performance via 7200rpm platter speed and some slight adjustments to the MTC so as to be able to both an excellent ‘C’ / ‘Operating System’ drive or ‘D’ / ‘secondary’ storage option for consumers.
Seagate 10TB BarraCuda Pro 9
The last round in the initial Guardian salvo is the FireCuda. This is a solid-state and hard-disk drive ‘hybrid’ model that has been tailor made for home consumers and systems builders alike. Thanks to its powerful controller, good NAND, and Seagate’s IP in both HDD and SSD arenas expect to see these drives cropping up in everything from laptops and notebooks to prebuilt systems from all the major system builders. In other words, it represents Seagate getting back into the SSHD corner of the marketplace with all the flair and style they are known for.
  • 5. Closer Look
Page 3 of 16
Tags: BarraCuda ProreviewreviewsSeagateUnboxing
The Novice’s Guide to Mining
The Novice's Guide to Mining
