Home Processors (CPU)
Ryzen 5 2400G and Ryzen 3 2200G Review
Putting the G back in Gaming
in Processors (CPU), GPU, Recent, Reviews
HP Pavilion Gaming Desktop Computer, AMD Ryzen 5 2400G, NVIDIA GeForce GTX 1060, 16GB RAM, 1TB...
HP Pavilion Gaming Desktop Computer, AMD Ryzen 5 2400G, NVIDIA GeForce GTX 1060, 16GB RAM, 1TB hard drive, 128GB SSD, Windows 10 (690-0048, Black) (3LB74AA#ABA)
AMD Ryzen 5 2400G Processor with Radeon RX Vega 11 Graphics - YD2400C5FBBOX
AMD Ryzen 5 5600G 6-Core 12-Thread Unlocked Desktop Processor with Radeon Graphics
7. Temperature, Sound Results
  • 3. How they differ
  • 4. A Closer Look
  • 5. Test Bed
  • 6. Overclocking
  • 7. Temperature, Sound Results
  • 8. Adobe Performance
  • 10. PCMark and POV-Ray Results
  • 11. AC:S & BF4
  • 12. Crysis 3, GTA V, Metro LL
  • 13. winRAR and x264 HD
Temperature Results
For Idle tests, we let the system idle at the Windows 10 desktop for 25 minutes and recorded the peak temperature. For Load tests we ran AIDA64 for 20 minutes.
Ryzen 5 2400G and Ryzen 3 2200G Review 23
Sound Level Test Results
For Idle tests, we let the system idle at the desktop for 25 minutes and recorded the peak temperature. For Load tests we ran AIDA64 for 20 minutes.
Ryzen 5 2400G and Ryzen 3 2200G Review 24
As you can see the Stealth is a decent enough cooling solution for its class, it is just that it gets outclassed by the AMD Spire cooling solution. Put another way if you plan on overclocking, or just want to get the most out of your shiny new Ryzen APU an aftermarket cooling solution may be a wise investment.
  • 4. A Closer Look
  • 5. Test Bed
  • 6. Overclocking
  • 11. AC:S & BF4
Page 7 of 15
Tags: AMDAPUBudget gamingGPURyzenRyzen 3Ryzen 5
Seagate 10TB BarraCuda Pro
