PNY GTX 780 Ti XLR8 Review
in GPU, Reviews
PNY 780 Ti Cover
PNY GeForce GTX 1080 Ti 11GB Blower Design (VCGGTX1080T11PB-CG2) Graphic Cards
PNY XLR8 CS3040 2TB M.2 NVMe Gen4 x4 Internal Solid State Drive (SSD) - M280CS3040-2TB-RB
PNY XLR8 Gaming 16GB (2x8GB) DDR4 DRAM 3200MHz (PC4-25600) CL16 1.35V Dual Channel Desktop (DIMM)...
PNY XLR8 Gaming 16GB (2x8GB) DDR4 DRAM 3200MHz (PC4-25600) CL16 1.35V Dual Channel Desktop (DIMM) Memory Kit – MD16GK2D4320016AXR
6. Metro: Last Light Gaming Benchmark
  • 3. A Closer Look at the PNY GeForce GTX 780Ti XLR8
  • 5. Sleeping Dogs Gaming Benchmark
  • 6. Metro: Last Light Gaming Benchmark
  • 7. BioShock Infinite Gaming Benchmark
  • 8. Tomb Raider Gaming Benchmark
  • 9. Batman Arkham Origins Gaming Benchmark
  • 10. Battlefield 4 Gaming Benchmark
  • 11. Assassins Creed: Black Flag Gaming Benchmark
  • 12. Call of Duty: Ghosts Gaming Benchmark
  • 13. Crysis 3 Gaming Benchmark
  • 15. Overclocking
  • 16. Performance Summary & TL;DR
  • 17. Score Card
  • 18. Closing Statement
Metro: Last Light is a DX11 first-person shooter video game developed by Ukrainian studio 4A Games and published by Deep Silver released in May 2013. The game is set in a post-apocalyptic world and features action-oriented gameplay. The game has a benchmark component to it that mimics game play. Scene D6 was used and an average of four runs was taken.
The settings used in the testing below are Very High for quality and a resolution of 2560×1440 and 1920×1080. DirectX 11 is used, texture filtering is set to AF 16X, motion blur is normal, SSA turned on and tessellation is set to high.
PNY GTX 780 Ti XLR8 Review 17
PNY GTX 780 Ti XLR8 Review 18
Metro LL is one of those next generation games where you simply will not be able to have all the post processing turned to maxium if you want to play the game at something which remotely resembles fluid movement. Even at 1080P this game simply puts a big old hurting on video cards and no single card solution will let you run at above slide show levels. You will have to turn the settings down to get playable frame-rates. With that being said the PNY GeForce GTX 780Ti XLR8 does post significant improvements over a stock 780 and even outperforms the much more expensive Titan. Overall we saw a greater than 20% improvement over the GeForce GTX 780 and this level of improvement will translate a better looking game.
  • 15. Overclocking
  • 17. Score Card
Page 6 of 18
Nvidia’s Phil Scholz killed in Train Accident
Nvidia's Phil Scholz killed in Train Accident
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
